2000 AC500 Manual Shift selectable 4x4???
Old Mar 15, 2006 | 05:49 PM
RyanRX7's Avatar
Default 2000 AC500 Manual Shift selectable 4x4???
I did a search an got no clear answer on this question. I know for a fact that the 2000 model 500 manual didn't have selectable 4 wheel drive. I was wondering if there was ever a successful mod or write up that would allow me to make it selectable 4 wheel drive. I saw 1 post mentioning switching in a King Quad diff, but I didn't see any mention of what tear KQ to get the parts off of??? Any help would be great.
Old Mar 16, 2006 | 10:56 AM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
I think it is a standard part from your cat dealer. Cost about $100.
Old Mar 16, 2006 | 04:44 PM
RyanRX7's Avatar
naw, the part you're thinking of is for the 250 and 300 models. Thanks for the reply though
Old Mar 16, 2006 | 06:53 PM
swampyjunior's Avatar
RyanRX7,
I think I have seen a front diff locker made by Warn on an old king Quad which should work as a diff lock on your AC.
The 4 wheel selection lever made for the 250/300 may work if you have the part that it hooks to already on your front diff. It disengages the front dif totally.
I guess since there are similarities between the King Quad and AC 500 you could always swap out the diff housing or the diff all together.
hope this helps
SJ
Old Mar 17, 2006 | 10:49 AM
Catterman's Avatar
Got Milk!
I am pretty sure it will work, my dad has a 2000 500 4x4 auto and it can be taken in and out of four wheel drive. Maybe try going to the cat dealer and seeing what part # it is on the auto, and then add that to your manual. Should be the same I would think.
Old Mar 17, 2006 | 04:46 PM
RyanRX7's Avatar
Yup, I had the same idea......but the front diff is different in the auto. Therefore the piece that the 4 wheel select handle on an auto would hook to isn't there. The diff also attaches differently to the drive output. The auto uses a universal joint, the manual doesn't. Thanks for the suggestion though.
Old Mar 17, 2006 | 05:17 PM
RyanRX7's Avatar
Upon fruther research I could swap out the front diff and purchase the selector handle. But there is a piece I found the auto to have as well that I do not. They call it a "secondary gear shift assembly" it looks like a little plunger button. Anybody with an auto or 2001 model manual know what this is or what it does? I found that this part is exclusive to the models with selectable 4 wheel drive, I just don't understand where it is located on those models or what it does. Thanks
Njrider1230
Jul 29, 2023 05:16 AM
merryman
Jan 19, 2016 04:29 AM
bigred20653
Aug 31, 2015 12:41 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
