Sport Quads Discussions on sport quads.
Sand stars or sand sharks?
Old Mar 15, 2006 | 07:57 PM
hondabuster's Avatar
Default Sand stars or sand sharks?
I have a 300ex, totally stock, and was looking at these two tires for the rear. Most of the comments ive heard , are to get the sand stars. Are they that much better? Is there a diffeemce when resellling later?
And on the rim diameter...is bigger dia perferred over the smaller dia? Im looking to get 10 inch rims.
All responses are welcome.
Old Mar 16, 2006 | 11:59 PM
powerstroke01's Avatar
Stars are better than sharks, and 10" rims look better... Thats all i know. lol
Old Mar 17, 2006 | 12:56 PM
I like the looks of the geckos too, but so far everyone ive talked with, has said to avoid them. Deffinetly the 10 inch rims look better.
Old Mar 18, 2006 | 10:19 PM
Lefty31's Avatar
Well hondabuster.....I've been told don't know if its fact or not but i've been told to stay away from Sand Stars unless i had a 400 motor or bigger..... i don't know if they make that big o' difference or not. and you might wanna look around for a good set of used sand sharks....we got us some for out 250ex for 90 with little wear on them. Either way you'll be happy they are both great! good luck and i haven't heard anything good 'bout geckos
Old Mar 18, 2006 | 11:30 PM
I was concerned about being able to spin the tires, with only a stock 300ex, and sand stars. I like the looks, and they sure look like they will hook up good, but the fun of going to the dunes, is in the spinning and sliding and roosting (as much as a 300 will allow).
Thanks for the responses, anyone else?
Old Apr 24, 2006 | 05:50 PM
MenageAquad's Avatar
Ya, stay away from Geckos. They're heavier than the others. You see a lot of them though because you can usually get them cheaper.
Old Apr 24, 2006 | 06:11 PM
ShadyRascal's Avatar
Get the 8" rims. At higher tire speed, the more tire sidewall allows it to baloon up (picture a top fuel dragster tire) which then lessens your contact patch and drag. You will have higher top speed. The Stars are a good tire on most anything, and I think they could be a touch lighter in weight than the Sharks, and weight is everything.
Old Apr 24, 2006 | 06:36 PM
Yoshimura660's Avatar
i have the sand stars and love them they worked good for racing and just an overall good sand tire.
Old Apr 26, 2006 | 10:13 PM
YFZracer12's Avatar
Sand Stars there a whole inch tall run em about 3-4 lbs of air unless u are drag racing i like to run about 6-6 1/2 depending how the sand is
Old May 18, 2006 | 09:44 AM
maxxedouty's Avatar
I
