400EX burning oil at cold start
Old Mar 17, 2006 | 12:03 AM
MasterRaptor's Avatar
Default 400EX burning oil at cold start
My 400 kills all flying bugs at startup. I have to make sure the garage door is open before I start it. It's an 02, but it does have that many hours on it. It's still on the original tires. Its hard to believe that the rings are worn already or even the valve seals.
Many 400's that I have ridden behind have the burnt oil smell. And I know a couple guys that have done a top end because of burning oil.
So, what's the deal? Do I need to do a top end? Or, is it something else? I heard that sometimes the crank case breather dumps oil into the air intake. Is this what's going on?
Thanks!
Old Mar 17, 2006 | 02:23 AM
Exrider22's Avatar
i went through the same thing with my kfx400. I just got it back with a new cylander, piston and rings, and its only an '05,. the onnlyy way u can know for sure is by looking inside.
Old Mar 17, 2006 | 10:11 AM
It's just that this bike has low hours and is driven by chicks and kids.
I beat the living tar out of the Raptor with 10 times more hours and never burn any oil.
The 400EX is way more solid of a motor than a Raptor...so I thought.
It just doesn't compute. Maybe I put too much oil in it or something.
Old Mar 17, 2006 | 10:34 AM
monster88's Avatar
id do a compression test and a leak test. See if there is any oil getting through the rings.
Old Mar 17, 2006 | 10:42 AM
Good idea. Does any one know what the cranking pressure should be?
Old Mar 17, 2006 | 04:04 PM
400eecksRider's Avatar
new piston and rings solved my smoking and burning oil. Yep, should look inside to know for sure.
doesn't matter who rode it.
Old Mar 17, 2006 | 04:58 PM
ddrumman2004's Avatar
My g/f's 04 Yamaha Bruin started doing the same thing right after I changed the oil in it last fall. I used Castrol oil at the time so I changed it back in January to Amsoil 0w-40 synthetic and the oil burning stopped.
The money spent for oil and filter is cheaper than a top end rebuild.
Old Mar 17, 2006 | 09:06 PM
monster88's Avatar
the compression should be at 125. Do a leak test by putting a few drops of oil in the cylinder. Then do the compression test again. If the compression is lower that means ur leaking oil through the rings.
Old Apr 10, 2006 | 05:40 PM
The thing just stopped burning oil on it's own. I did nothing to it. Maybe I put too much in it when I did the oil change. How many quarts is it supposed to take?
Old Apr 10, 2006 | 07:01 PM
quad2xtreme's Avatar
Just under 2 quarts.
