Carb Troubles
Old Mar 18, 2006 | 11:55 PM
nofearatv's Avatar
Default Carb Troubles
I have a honda trx 300 4x4. I just bought it from a guy and found out shortly after it has problems ideling I think. I found you have to give it half-full choke to keep it running. Giving it no choke will make it stall. Is this normal or do I have to adjust my carb.
Old Mar 19, 2006 | 02:46 AM
hondabuster's Avatar
It could be an air leak, around the carb to intake or intake to head . Could be bad gas, could be mixture screw too lean, or could be a dirty carb (inside of the carb, that is).
Old Mar 19, 2006 | 05:03 PM
keithbry's Avatar
ran into a lot of this with a honda 250x(same carb)come to find out the proble, was in the valves and in a very loose cam chain.Learned quick that carbs do get dirty and out of adjustment,but most of the time it will lie in the valves or cam chain.
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
