01 ds650 chain noise
I recently purchased an 2001 ds650. The motor and everything else is running very smoothly. However, the chain is loud and sort of anoying. It sounds like it is banging in the chain feed by the upper sprocket. I recently had the wheeler tuned and the mechanic said the chain was at the correct length. There aren't any other Bombers where I am from, so I cannot compare and hear another ds650's chain. Can anyone tell me about 2001 ds 650 and appropriate chain noise? It does not make the noise in higher rpm's. Is the noise common?
A lot of people ran that 00 and 01 stock rubber chain roller right off - then the chain hits the bolt and makes a ton of noise. My boss had the old rubber chain roller and it was barely hanging on still.
If you do not have your rear ride hight set up correctly you will always be rubbing on the upper chain roller. Althouigh it may feel better to have the rear too low is not correct. With the rear all the way extended you should have 4"-5" of sag. The lower rear feels better because the stock camber... or caster (I always mix those up) is not right. Look into the ASR upper a-arms to fix that problem if it is still bugging you.
jrooker6
Apr 23, 2016 07:36 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
