Front end question on a 700
Old Mar 22, 2006 | 12:33 AM
Catchup2's Avatar
Default Front end question
Just got my Sportsman 700 and was giving it another once over and changing all the fluids. So this is my question.
The front end third member(is what it is call on a truck) where the 2 shafts going to the wheels go into this is it supposed to be a bit of slop there. If i grab the yoke i can move it a little in a circle(not twisting it around) like up down back forth sort of . Is this is the norm for these front ends and how much play should be there?
Thank you
Old Mar 22, 2006 | 09:17 AM
Catchup2's Avatar
Default Front end question on a 700
No one got an answer to my diff question??
Old Mar 22, 2006 | 10:56 AM
madmatt1971's Avatar
I'm not sure what your talking about. Are you talking about where the axels go into the hubs?
Old Mar 22, 2006 | 12:41 PM
Catchup2's Avatar
The front gear box It has one power shaft going in and one going out to each front wheel hub. there are universal joints just before it goes into the caseing (not the end with the cv boots) the part with the awd system. Just wondering on how much play(slop should be there.
Thanks for the reply. This is my first quad, and i wanted to make sure things are OK before i take it out this weekend
Old Mar 22, 2006 | 12:47 PM
You and me both on the first Quad. I'll look at mine tonight if I get a chance and let you know if I have any slop. I would think the CV joints would be tight. I think there both the inner and outer joints are CV joints just different types.
Old Mar 22, 2006 | 01:40 PM
Catchup2's Avatar
There is on play in cv or univeral there in good condition. its where it passes through the caseing of the front gear box. can pic be posted in forums? I could take a pic and show you what I mean
Thanks again
Old Mar 22, 2006 | 02:06 PM
I know pics can be posted but have never tried.
Old Mar 23, 2006 | 08:45 AM
Kerbbirds's Avatar
some slack is normal.
Old Mar 23, 2006 | 10:34 AM
Catchup2's Avatar
Cool thanks for the replys. Going out thia weekend, with some friends, I will be the only polaris in the group. DId want to run into a problem first time out.
Old Mar 23, 2006 | 04:55 PM
sport700man's Avatar
Both sides of my diff are a little bit loose, I would like to take it apart, and see if there is a bushing or a bearing that can be replaced. I am pretty sure that water gets in there. I have a little bit of a rust (?) trail below these seals. From what I have heard, a bit of slop is normal.....
JackTheKing
Jul 14, 2015 09:09 PM
1966F100
Jul 12, 2015 03:08 AM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
jettman
Jul 6, 2015 12:16 PM
