need quick help with bleeding ?
Old Mar 25, 2006 | 02:29 PM
qball830's Avatar
Default need quick help with bleeding ?
I am in the middle of changing my oil. I have done all the necessary things I found on here. So my question is when I am doing the bleeding thing ( I have a 2000) and I turn the engine over with the kill switch on am I supposed to see oil coming out of the hole where the screw is or the hole just to the left of it. Oil comes out of the hole.
Old Mar 25, 2006 | 02:40 PM
FatHolly's Avatar
I don't remember which hole it comes out of but as long as there is oil pumping to the filter housing you should be good. Let it pump until you see clean oil to be sure. If, when you go to start it up, the oil pressure light does not go off, bleed again. Good luck
Old Mar 25, 2006 | 03:21 PM
yjacket2001's Avatar
http://cgi.ebay.com/ebaymotors/Mityv...14439442QQrdZ1
5 min job with this $21 gadget!
Old Mar 25, 2006 | 04:17 PM
qball830's Avatar
I put the filter in and started it up. The oil light was on for about 3 seconds and gone. I rode it up and down the street and also let it sit and idle for a while. The oil light never came on. I didn't even turn the screw. I tried and couldnt get it so decided to see what would happen if I turned it over with the kill switch on. Like i mentioned first, oil came out of the hole just to the right of the screw. Someone let me know if I am not ok, but it seems to be fine.
MikeyBoyesq
Sep 22, 2015 10:02 AM
Rooky
Sep 9, 2015 03:16 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
