Recon electrical problem
Old Mar 25, 2006 | 08:51 PM
twt's Avatar
twt
Default Recon electrical problem
I shut it off and now nothing, no lights no electrical power anywhere.
I jumped the selinoid and it cranks but will not start, and still no lights.
Please help
Old Mar 25, 2006 | 10:38 PM
1988TRX250R's Avatar
If I remember right, there isn't a fuse box on this machine, just a couple of in-line fuses. Check these first along w/ the battery connections. If both are good, the easiest way to diagnose your problem is w/ a test light and a wiring diagram. Start from the battery and follow the electrical path until you don't have voltage.
Old Mar 26, 2006 | 12:09 AM
LittleBill's Avatar
kill switch is on, can almost gurantee it
Old Mar 26, 2006 | 02:26 AM
recon99's Avatar
the kill switch won't keep the lights from turning on. It probably blew the fuse under the seat by the battery. There's just one blade fuse that protects everything, I think it's a 15 amp
Old Mar 26, 2006 | 11:57 AM
twt's Avatar
twt
I changed the fuse by the battery nothing, is there another one somewhere?
Old Mar 26, 2006 | 01:01 PM
recon99's Avatar
That's the only fuse. Check electrical connections, and unhook the key switch and test it with a multimeter.
skinnyr6
Aug 25, 2023 02:18 AM
chammerbeck
Jul 17, 2015 08:06 AM
Chocobamofo
Jul 10, 2015 07:46 PM
MNatv89
Jul 7, 2015 11:36 AM
ranvette
Jul 4, 2015 06:13 PM
