spark plug
Old Mar 26, 2006 | 06:55 PM
billyj's Avatar
Default spark plug
raptor 660....where is my spark plug located?
Old Mar 26, 2006 | 07:15 PM
maddog56's Avatar
Default spark plug
Under the gas tank in the front of the engine on top of the head. You should not need to pull the gas tank and plastic to get it out. Just follow the big black wire from the little black pack on the shifter side of your frame behind your headlight, it's the spark plug wire. Just pull that out and use the tool in your tool kit to remove it.
Old Mar 26, 2006 | 07:18 PM
billyj's Avatar
Default spark plug
oh i found it, i just didnt want to break anything trying to find it, thanks
Old Mar 26, 2006 | 07:21 PM
fizzak's Avatar
Default spark plug
No offence but if you can't find the plug perhaps you should have an experienced mechanic look at your quad. Really, not trying to be a jerk here.
The plug is located on the very top and front of the engine. There is the spark coil bolted on the frame on the left and under the fender. It has a thick wire running to the location you seek. Remove the boot by yanking and twisting. You can get the plug out with I think an 18mm spark plug socket and a 3" extension. When you replace the plug do not overtighten it, just needs to be snug.
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
