Engine Smoke...
Old Mar 26, 2006 | 10:38 PM
nofearatv's Avatar
Default Engine Smoke...
My honda trx 300 1993 engine is starting to smoke. I left the choke on for a week to keep it running and not die since the carb was messed up I thought. Anyways since I used the choke all week and let it run lean I think I blew the circlips or rungs on the piston. So I bought a new after market wiseco piston hoping this will fix the problem. Can anyone tell me if I will need to take the engine out of the frame and if I will need to drain it of oil and also will it need any adjustments or will it be a drop in and run method? I also bought a new head gasget set.
Old Mar 27, 2006 | 02:52 PM
RobGonz's Avatar
you should tell your honda that smoking is bad and then maybe it will quit smoking.
Old Mar 27, 2006 | 03:35 PM
nofearatv's Avatar
Could I get any serious help?
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
