Stock cam timing question.
Old Mar 27, 2006 | 02:17 PM
Halfliter's Avatar
Default Stock cam timing question.
After getting the correct head volume for 11:1 compression for my 730; My head is raised up a bit from stock. Now the cam timing marks don't line up perfect. I can make them a little advanced or a little retarded from stock position. What would be my best choice. All I do is trail ride. However, I never run my mouth, but sometimes I have to represent if needed.
The motor, for now, has stock cams, stock carb, stock air box, and stock ignition, the only mods are 730 cc, bigger valves, 11:1, a little grinding in the head, and an end cap.
Any opinions would help. Thanks.
Old Mar 27, 2006 | 03:11 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
Ive ran a sleeved 730 with 1 tooth advanced on the cam and also advanced on pick-up with the ron woods box. It had great top end but the bottom suffered when on gas not alky.
Depending on how close the marks are I would go retarded if you trail ride. I have never tried it so I cant say much about it. You should have some serious bottom end though.
EDIT:Whoops Sorry it wasnt stock cams.
ERBEDS650's Avatar
Just Curious? With all that work why just stock cams?
Old Mar 27, 2006 | 04:09 PM
yjacket2001's Avatar
Old Mar 27, 2006 | 04:13 PM
ERBEDS650's Avatar
I understand Yjacket but say some webs 110 he gets the bottom end and some extra Midrange and he can use stock springs if he wants to.
Was just a thought, with stock cams thats gonna be a fun wheelie machine! woohoo!
Old Mar 27, 2006 | 04:16 PM
ok
Old Mar 27, 2006 | 06:23 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
1- Retarding cams make more top end - Advancing cams make more bottom end.
2- When on left side of motor looking at cams:
a. Motor turns counterclockwise.
b. If intake cam(right side) - timing marks are level. It is normal for the exhaust cam to be slightly retarded. That is, exhaust cam to be clockwise a few degree's. Under load, from crank pull and the hydralic tensioner pressing harder, the cams will be more parallel.
3- By raising the cylinder and head you have caused the chain to pull the cams more counterclockwise or advance the cams. One tooth on the chain is 21 degree's. You can only retard the intake cam. This moves the intake valves even further from having interference with the piston. With the 730 you need more top end. This extra overlap will draw more air/fuel into the cylinder. I would not retard the exhaust since it may hit the piston.
Old Mar 27, 2006 | 06:43 PM
OMR- That is wierd, A few people have said the same thing about the advance being more on bottom.. On both bikes I had with advanced timing I felt more bottom end with timing being retarded... I dont know why...
Old Mar 27, 2006 | 08:15 PM
222's Avatar
222
annihlator, that would depend on which cam you are talking about, intake or exhaust?
halfliter- got a digital camera?
222
Old Mar 28, 2006 | 10:56 AM
Got it 222.... I dont remember which cam exactly, But as soon as we lined them up right, The bottom came alive, So OMR and you are probably right.
