Stock cam timing question.
Old Mar 28, 2006 | 02:17 PM
Halfliter's Avatar
Default Stock cam timing question.
Thanks for the input men.
The reason I'm still using stock cams is that I'm not sure what cams I will need. I knew what I didn't like about the stock power curve (or lack of it). After I blew it up, I only replaced the parts I needed. Piston, valves and bore. Once its together and ride it, if I feel its still too much of a terd, I can tell HP Reasearch what I like and don't like and they can give me the right cam based off of that. Otherwise, now I have to guess. Cams should be easy to change later.
222, I will take some pics tonight and put them on my picture page. Thats the only way I know to show them to you. I hope the piston is not that close to hitting if I am a few degrees off. That's not the kind of motor I want to build. Just gas and go.
Old Mar 29, 2006 | 09:04 AM
Halfliter's Avatar
I posted a couple pics in my bio thingie. One way is close and the other is pretty far out. This should be a common isssue since its a piston and comp ratio a few people are using. Maybe I'm the only one using stock cams. However, the aftermarket cams have to work both ways.
Old Mar 29, 2006 | 02:35 PM
222's Avatar
222
Pic 1 and 2 look perfect, NOT pic3 and 4.
222
Old Mar 29, 2006 | 05:41 PM
Halfliter's Avatar
Pics 1 and 2 are clearly the closest to stock position. So that is a little retarded exhaust and advanced intake. That small amount will not interfere with the piston? Here I thought I was going to have to re-dowel pin the gears. Thanks for your help.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
1966F100
Jul 12, 2015 03:08 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
