2006 500 EFI WONT KEEP CHARGE
Old Mar 28, 2006 | 01:07 PM
Shedman's Avatar
Default 2006 500 EFI WONT KEEP CHARGE
I have 101 miles on atv and no problems but i shut it off 2 days ago and the fan kept running so i shut the key off 2 times and it quit. But that afternoon it was dead no juice. I charged it and it fired up. But when i let it sit a few hours its dead again ?? Any ideas on how and what to check
Old Mar 28, 2006 | 09:14 PM
Indyguy's Avatar
I'd say that it's time to test the warranty service at your dealer. There is a well know problem with a batch of fan relays, normally they don't come on and it over heats.
If you're handy with a multi meter you can check the amount of current draining out of the battery when it's off. But if it's dead in two days, it won't take a rocket scientist to find the problem.
Old Mar 28, 2006 | 11:37 PM
bigfatguy's Avatar
i had only 40 miles on my 06 500 efi when the hot and check engine light started flashing i took it in and they replaced a resistor thats about as close to your problem i can get
Old Mar 29, 2006 | 12:39 AM
Shedman's Avatar
charged battery today and its still holding up. Let you know what happens tommorrow
Old Mar 29, 2006 | 12:55 AM
Smitty4's Avatar
The fan motor draws a huge amount of amperage. If the battery was not fully charged during dealer prep (alot of the time, they'll just toss the acid in and ship her out....usually @ big, high volume dealerships), then that would kill it in a hurry, regardless of how well the charging system is.
I'd give the battery a good overnight charge and see what happens from there. Should stay around 12.6- 12.8 volts 1 hr after charge is stopped.
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
akguy31
Aug 31, 2019 04:34 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
snowolson
Aug 31, 2015 03:51 PM
