400ex question
Old Mar 28, 2006 | 07:12 PM
Wreckless400ex's Avatar
Default 400ex question
alright, well first off my 400 was poppin alot when i was bringin it down on compression goin down hils and stuff ever since i put my new head gasket and oversize studs in it, my first thought was to change the plug, so i did and it was still doin it, so i went and re-spaced my valves to the honda specs and it is still poppin but not quite as bad so i was wondein if yall have any sugestions that might solve this. another thing, when i was checkin my valves i noticed a lil bit of oil around my head gasket, i know its not blow cause i have blown plenty head gaskets up untill i installed my oversize head studs, i have about 2 rides worth of time on this new gasket and stud setup and i am thinkin i should go in and retorque the nuts, what do ya all think bout doin that?
Thanks Wreckless
Old Mar 28, 2006 | 08:23 PM
TractorPacker's Avatar
Do you have a balloon?
Popping on decel is a lean air screw or pilot jet. Back the air screw out, or go up one on the pilot jet.
Old Mar 28, 2006 | 08:29 PM
i hate to say this but i have never been able to find the air screw on my carb, would about bumpin the main jet down a size
Thanks Wreckless
Old Mar 28, 2006 | 08:39 PM
RacinJason's Avatar
Yes re-torque the head
the a/f screw is on the bottom of your carb...loosen the clamps and try to spin it far enough to see in there
Old Mar 28, 2006 | 08:41 PM
Under the carb, between the bowl and the front of the carb. It is brass with a flat slot head. It should be just about flush with the carb.
Old Mar 29, 2006 | 06:42 PM
Well i messed with my air fuel screw today and it didnt seem to make a differance, i checked it and when i started it was out 3 full turns, so i tried 2 turns out and then 3 and a half and i was stuck with the same loud popping noise any more sugestions will help as well, another thing is no matter how far i turn my idle ajustment screw in my bike still wont idle, it seems like the idle screw teeds to go about another half turn.
Thanks wreckless
wendal
May 9, 2024 09:29 PM
bigred20653
Oct 2, 2015 10:05 AM
wendal
Sep 15, 2015 01:50 PM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
