500 pipe fit on a 400??
Old Mar 29, 2006 | 12:34 AM
crashby's Avatar
Default 500 pipe fit on a 400??
I am looking to buy a pro circuit t-4 complete system, wondering if the one for the sportsman 500 will fit on my 400. The pipe for my 400 at procircuit.com is $574, and i found the system at denniskirk.com for $474, but the only applications is for a sportsman 500. i think it should fit, they are basically the same bike, but im not sure.
Old Mar 29, 2006 | 08:02 PM
crashby's Avatar
ANYONE?????
Old Mar 30, 2006 | 12:42 PM
cbmboy's Avatar
your not getting much help so i'll throw my 2 cents in.... but i will tell you this is more or less a guess
i would expect that the exhaust will fit... but wont run right... the 500 is a 4-stroke, the 400 is a 2-stroke... the difference in the way then engines run is vast... i'm not positive, but to me that just wouldn't be smart...
if it did work it would be purely out of coincidence, not intent.
Old Mar 30, 2006 | 12:49 PM
ScramblerXLE's Avatar
cb, sorry, but that's not true [img]i/expressions/face-icon-small-smile.gif[/img] your 400 sportsman is actually the 425 motor from the magnums and the xpeditions in the days of old... i know that the cam from a 500 is very similar (i think i remember a guy who swapped them, but i'm not sure) one thing you may do is to goto your local dealer and see if the head-pipe is the same part number for bothe machines. if it is, you're in business. [img]i/expressions/face-icon-small-smile.gif[/img] good luck!
Old Apr 3, 2006 | 08:11 PM
crashby's Avatar
Anyone else know if it will work??
Old Apr 3, 2006 | 09:15 PM
Backinthesaddleagain's Avatar
I don't know for sure. But I believe the pipes should be interchangeable. I'm pretty sure the 400 (425cc) and the 500 (499cc) are basically the same engine except for stroke and bore. I think the stock pipe and the entire exhaust on the 400 and 500 are the same. A check with dealer on part #s as mentioned above should confirm.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
