Exhaust for Raptor 700???
Old Mar 29, 2006 | 06:41 PM
Deeker's Avatar
Default Exhaust for Raptor 700???
I recently bought a raptor 700, but I want to know which is the best exhaust to use. I want something with full range power and something that sounds good, but not too loud. Also, do I need to get any other accessories in order to have a new exhaust system. I'd appreciate any info. Thanks
Old Mar 29, 2006 | 07:56 PM
RaptrGYT350R's Avatar
my 700's got a GYT-R set up on itand it works great. It sounds GREAT and is a nice up in power from stock(not huge but definately noticable)... Yamaha advertizes a 13% increase over stock without the filter kit and 30% with. This is without an EFI controller... so I'm slightly skeptical about their numbers but I'd guess that the full system, with the filter kit will run probably a 20-25% increase over stock but will slightly lean it out. Maybe the GYT-R stuff is designed to be within the range of where the stock EFI can handle without running too lean... maybe not.
Old Mar 29, 2006 | 10:12 PM
Ozark38's Avatar
Welcome to the site!......There are many nice pipes (and no bad ones really) to choose from. I prefer HMF but would consider Curtis Sparks, LTE duals, CT, Trinity, and LRD. Probably some others I'm forgetting to mention as well. Even with just a pipe you really should have an EFI controller installed because the factory EFI don't compensate enough for mods, just altitude changes. To get the MOST out of your pipe, install a Pro-Flow K&N (or equivlent) and remove the air box lid..............but either way, you really do need an EFI controller.
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Sep 10, 2015 01:56 AM
Bigtwin700
Sep 9, 2015 09:32 AM
1ArmBandit
Sep 8, 2015 08:59 PM
black_thunder
Sep 7, 2015 01:24 AM
