Am I running too cold?
Old Mar 29, 2006 | 06:49 PM
1882's Avatar
Runs a Full 730 Race Build!
Default Am I running too cold?
I just installed a PWR radiator on the 730 and I use Alba's carbon fiber shrouds, I installed an ESR temp. guage after the PWR install so I have no baseline but my 730 now runs no hotter than 165, she'll climb into the 200's if idling but even when I run the snot out of her she never gets over 165, is this going to be a bad thing? Any harm in running this cool?
Old Mar 29, 2006 | 06:57 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
I ran mine about 165 for years... But I never let it go into the 200 that seems dangerous to me.
I think 170-175 is the sweet spot.
Old Mar 29, 2006 | 07:02 PM
1882's Avatar
Thanks man, I feel better now. By the way, those PWR radiators are pretty darn nice if anybody is considering getting one, perfect fit and sure keeps things cool.
Old Mar 29, 2006 | 07:51 PM
On all my motors ive ran, I take out the thermostat and cut out the brass piece and then re install thermostat. Seems to run real cool like that but make sure you bleed it good. I also run my fan on a toggle switch so when The bike makes a BUNCH of passes back to back I can keep it near 175.
Old Mar 29, 2006 | 09:06 PM
IdahoVinnie's Avatar
Okey guys, help me learn about atv engine temps.
When I had my stock car with about 450 hp, my engine builder recomended running at about 210 to 220 degrees for the best burning of the mixture in the cylinder (even nascar runs about this temp). Is a built atv that much different? If so, then why?
Old Mar 29, 2006 | 09:36 PM
I think the red (dummy) light on our Ds comes on at around 210 for overheat.. Around that area. By then its too late. I think the recomended operating temp is about 175. I might be off a few points.
Old Mar 29, 2006 | 09:49 PM
Doctorturbo's Avatar
GOT BOOST!
An engine is an engine is an engine. It dosen't know it it's a Briggs or a Rodeck. So no, they arn't different. If you have a cold engine your loosing HP. The heat that is inside of the engine is what pushes the piston down. If you have your engine set too cold then the water is drawing the heat (energy) out of the combustion chamber. I set our circle track engines at 180. Drag engines can go to about 205 to 210. I don't like getting the circle track engine that hot because you can get into traffic and start loosing water. I try to stay out of traffic when I drag race. [img]i/expressions/face-icon-small-happy.gif[/img]
I never did like to run a cold engine, and I really don't like hammering on a cold engine.
Be sure to check the oil a lot if you run this thing that cold.
Old Mar 29, 2006 | 11:06 PM
Sandaholic's Avatar
According to the manual: The thermostat opens at 185* and closes at 167*. The fan turns on at 221* and turns off at 205*
Old Mar 30, 2006 | 02:52 AM
ERBEDS650's Avatar
Just a thought, I havent taken the thermostat out yet to see how its placed, but could he have placed in backwards?? Oh never mind, its on the motor.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
bbehrendt
May 28, 2015 09:25 AM
