Am I running too cold?
I just installed a PWR radiator on the 730 and I use Alba's carbon fiber shrouds, I installed an ESR temp. guage after the PWR install so I have no baseline but my 730 now runs no hotter than 165, she'll climb into the 200's if idling but even when I run the snot out of her she never gets over 165, is this going to be a bad thing? Any harm in running this cool?
On all my motors ive ran, I take out the thermostat and cut out the brass piece and then re install thermostat. Seems to run real cool like that but make sure you bleed it good. I also run my fan on a toggle switch so when The bike makes a BUNCH of passes back to back I can keep it near 175.
Okey guys, help me learn about atv engine temps.
When I had my stock car with about 450 hp, my engine builder recomended running at about 210 to 220 degrees for the best burning of the mixture in the cylinder (even nascar runs about this temp). Is a built atv that much different? If so, then why?
I never did like to run a cold engine, and I really don't like hammering on a cold engine.
Be sure to check the oil a lot if you run this thing that cold.
Frisky2050
04-09-2020 11:19 AM
bzdok1234
30
02-23-2016 01:55 PM
