Water in transmission....
Old Mar 31, 2006 | 01:14 PM
EdgeRacing's Avatar
Default Water in transmission....
is there any easier ways to get water out of the tranny case other then changing the oil repeatedly?
Old Mar 31, 2006 | 01:19 PM
MYWAYOUT's Avatar
The only thing I could suggest is compressed air and blow out what you can.... add a little oil... repeat the blo-job...and keep going until clear.... maybe move the wheeler forward and back to completely clean the moving parts....
Been done 3 times on my 03 sp 700......
Old Mar 31, 2006 | 05:52 PM
EdgeRacing's Avatar
ok thanks
Old Mar 31, 2006 | 06:24 PM
Jayblazer's Avatar
would filling it with pb blaster work?
Old Mar 31, 2006 | 06:31 PM
EdgeRacing's Avatar
i dunno if it would or not. i was thinking about spraying brake cleaner in there to see if that worked. but i dont want to mess anything up.
Old Mar 31, 2006 | 10:54 PM
dontgetbehindme's Avatar
I rebuild Ford transmissions all the time and after cleaning with a pressure washer I use brake cleaner to get all junk and water out. I highly recommend using it to clean out the water. The good thing is it evaporates if you leave it vented for a short time.
Old Mar 31, 2006 | 11:12 PM
Be sure to use a non cloranated type.
Old Apr 1, 2006 | 05:10 PM
EdgeRacing's Avatar
ok cool... thanks man
Old Apr 1, 2006 | 05:44 PM
Fireslayer's Avatar
If you can get your hands on a gallon jug of WD40, you could fill and flush the tranny a few times with it and probably get most all the water out before you put oil back into it. As Mywayout suggested it would be good to roll the machine around some with the WD40 in it to help get all surfaces coated and purge the water from any nooks and crannies between the gears. I would do this 2 or 3 times and then let it drain overnight so as much as possible could drain out. I've done this on engines and gearboxs that have been flooded before with good results as long as they only had water (no mud or debris) and you do it within a short time after the unit got flooded.(no time for rust to get started) Hope this helps.
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
