Need Help.....carb?
Old Mar 31, 2006 | 11:27 PM
qball830's Avatar
Default Need Help.....carb?
I spent the day at little sahara today and had a great time. Bike ran excellent for me. Got to meet cynick and ride with he and his family for a while. At the end of the day my bike suddenly started acting up. When I would gas it, the bike would act like it wasnt getting any gas. It would idle just fine, but when I would give it gas it would stall out. Next, we pulled out the choke and oddly enough it ran fine again with the choke out for a while including a few runs up sand mountain. Then as I was loading up it did it again even with the choke out. I assume it is a problem with the carburator. Can anyone help me out and tell me what might be wrong or if they have experienced something like this before.
Old Mar 31, 2006 | 11:46 PM
FatHolly's Avatar
Are you sure that you were not at the reserve line. My buddy had a problem that sounded similar a few weeks back. When I looked in the tank I saw gas but it was at reserve. Next I would check that fuel is getting into the bowl. Take the bowl off and turn your gas on. It should flow fairly freely. If you have gas there then I would look to a clogged main jet. Also make sure that the needle is seated correctly. Mine poped out after a backfire and it would idle, but any throttle would kill it. I just had to click it back into the grooves and it was all good. I'm no carb expert but its something to start with. Good luck.
