help with my Maxxis Razr II tires
Old Apr 1, 2006 | 12:50 AM
ThorMX902y's Avatar
Default help with my Maxxis Razr II tires
i have them all around but how much pressure should i run in them for the bakcs...i have 10 in now wat do u recomend?
Old Apr 1, 2006 | 01:48 AM
raptorgav's Avatar
10 is probably too much for any surface, in sand I run mine at 3/4psi and if I want to slide around a lot I go up to 5/6psi[img]i/expressions/face-icon-small-happy.gif[/img] Just try different pressures yourself, I have run them flat b4 and those sidewalls still hold up.
Gav
Old Apr 2, 2006 | 10:33 PM
ThorMX902y's Avatar
ok now how about the fronts?
Old Apr 2, 2006 | 10:37 PM
DuneRider650's Avatar
I ride a little here and there......
anywhere from 4-7 should be a good area....i run 4 in my rears and 5 in my fronts
Old Apr 3, 2006 | 12:05 AM
chirochris's Avatar
10 lbs..wow, must feel like riding on bricks..hard as hell
i run 5 lbs
Old Apr 3, 2006 | 12:37 PM
ThorMX902y's Avatar
yea it did... i run them at 5.5 now b/c i have a tendacy of debeading tires wen i ride... im on my thrid set of rims for the rear n ive had the quad sience november 1st[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Apr 3, 2006 | 01:15 PM
BajaX04's Avatar
I used to bend my rear rims (inside only) up really quick with my stock tires running low pressure. That was from hitting big rocks on the trails. Now with my Razr tires that seems nearly impossible. I had to use a hammer and a block of wood to make them round, but still running my stock baja wheels.
Old Apr 3, 2006 | 08:15 PM
400EXerciser's Avatar
I run the plain Razr's front and back. Most time I run them like alot of other people , 5lb front & 4lb in back. This is a good starting point to work with. I do not know about the Razr II but my Razrs on back are 6ply. They take a beating and keep on running. My other 4ply tires didn't hold up as well to rocks and sticks as the 6ply do and would bend a rim faster.
Old Apr 3, 2006 | 10:28 PM
atvaddict01's Avatar
I hit some stumps and rocks this weekend that would of made a
lesser tire cry.Very tight trails.
I run mine at 5-7.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
Alex Rodak
Sep 12, 2015 09:39 AM
