brand new baja 90 and 150 wont start
I went 2 pep boys 2 buy a baja 150. when they went 2 start it the thing wouldny start( just cranks) they tried 4 about 5 min. Then i asked 2 hear the 90 run. they got that 1 started but it wouldnt stay running after 5 min of reving it. The thing would not idle. So i opt not 2 buy either. what could the problem be.
I have worked on alot of the Baja atv's and 90% of the problems were carb adjustments. Some had the ignition wired wrong and some just did not know how to work them with the safety cut off. All of them did run fine once running. THe Baja brand is a pretty good quad.
you would think pep boys would be smart enought to check the atv out and make sure they start and ran after assembling them, i bet you'd have a difficult time trying to take them back if you didn't ask to have them started before buying and just assumed they ran and purchased them took the atv home.
Jun 8, 2015 06:45 PM
