transmission noise 1988 klf220
Old Apr 2, 2006 | 03:31 AM
fife's Avatar
Default transmission noise
1988 bayou klf220 transmission noise, help. pulled engine out, turn front bevel gear can hear noise, sounds like in trans. Next step split case i guess. any ideas. Also fileings in oil. ouch help
Old Apr 3, 2006 | 07:47 PM
Hayashi's Avatar
Default transmission noise 1988 klf220
Considering the age of your quad, I am suspecting if the excessive backlash of the front bevel gear is causing the noise in your trans. To tighten up the gap, you will have to install a correct sized shim. The spec is 0.06 to 0.13 mm for allowable backlash - hold the drive gear and move back and forth the driven gear. Replace existing shim(s) to bring the backlash within the spec. You would need a dial gauge to measure, and a defitnitely a service manual for more detailed procedure if you are not familar with this.
Old Apr 4, 2006 | 01:12 AM
fife's Avatar
Thank you for the info, i have a manual on order. I will measure the backlash and see what i come up with. Again thanks for taking the time to reply.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
