hard to start my wifes trail boss
Old Apr 3, 2006 | 04:58 AM
rob0990's Avatar
Default hard to start my wifes trail boss
We picked up a used trail boss 325 and it runs great once I get it started.If I dont start it once a week it is VERY!! hard to start.even using starting fluid.Does this bike have a throttle switch? I think it might be out of adjustment.how do I do that?
Thanks
Old Apr 3, 2006 | 09:01 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Do you use the choke when you start it? The idle adjustment screw is on the left side of the quad/carb. You'll know it when you see it. The mixture adjustment screw, you have to take the plastic plug out. A lot easier to do without the carb on the quad. I have a service manual at the house, if you need any info let me know.
The Trail Boss is cold natured. Once they get warmed up they run good.
Old Apr 3, 2006 | 09:06 AM
Blazer25's Avatar
I have a 2005 Trail boss and in cold weather it had a hard time idling. Try adjusting the throttle cable (up by the handlebars) - that helped mine. If that doesn't work, try adjusting the air screw.
Old Apr 3, 2006 | 10:03 AM
Lukester's Avatar
I wouldn't use any more starting fluid because I've heard some horror stories assoc. with it's use.
Have the battery checked. I would bet it's bad. Sounds like mine when I had a bad bat. anyway. Check the spark plug too.
Old Apr 3, 2006 | 06:13 PM
la90043's Avatar
if your new trailboss had been sitting for awhile "stored" the carburetor might have gunk in it. when the gasoline sits for many month's the molecules separate and create a gummy tar like substance. this gum clogs up passages through out the fuel system like fuel filter, petcock, carburetor. so thats is the most probable cause of your problem. clean or replace the parts. put in a new spark plug fresh new fuel also. when the atv is stored it must be stored with a fuel stabalizer to prevent this from happening again.
Old Apr 4, 2006 | 12:58 AM
Lukester's Avatar
la90043,
Good advise.
Old Apr 4, 2006 | 02:47 AM
ScramblerXLE's Avatar
my old TB still does this, it has a bad battery, but i don't use it much at all so i just let it sit for now... seems like the battery problem. i think mine needs its valves adjusted too as it does not run NEARLY as strong as it did when i first got it... oh well, hope that helps.
Old Apr 4, 2006 | 06:24 PM
la90043's Avatar
thank you lukester.
Old Apr 4, 2006 | 07:11 PM
ftwflh's Avatar
Put a full charge on the battry and if it starts easy get a new battry.If not adjust the valves.
1000gade
May 27, 2015 12:37 PM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
dunc_n
Aug 26, 1999 09:32 PM
Matt24
Aug 3, 1999 07:46 PM
