Sport Quads Discussions on sport quads.
graphite for chain lube
Old Apr 4, 2006 | 02:15 PM
cockadoodledoo's Avatar
Default graphite for chain lube
Can anyone tell me if graphite (the erasol type in a can) could be used on a o ring chain?
I tried a search but no luck.(I 'm not sure if I spelled "graphite" properly).
I've never heard of it before,just a brain wave I had.
Old Apr 5, 2006 | 01:09 AM
recon99's Avatar
It'll probably fling right off, it's a real thin lube like wd-40, right? I use an o-ring chain specific lube, it's thick and sticky so once it gets on there it doesnt fling off, and there's no possibility of it damaging your rings.
Old Apr 5, 2006 | 07:54 AM
I guess I have only seen it sprayed on slow moving chains..
Good point,it prob. would fling off.
Old Apr 6, 2006 | 09:49 PM
YFZracer12's Avatar
i dont know about using graphite but in sand i like to use WD-40 on my chian i use to spray yama lube chain crap on it but the dealer here told me i would be better off using WD-40 then a oil of some sort in dirt i just run reg. chain lube
Old Apr 9, 2006 | 12:29 AM
Wandell's Avatar
I've always read that all you need with an o-ring chain is a rust preventative since lubricant is sealed inside the chain. I also use WD-40.
Old Apr 9, 2006 | 01:06 AM
Scooter86's Avatar
Knows Old ATV Questions!
Graphite(yes, you spelled it OK) tends to turn into a sludgy mess when it gets wet. Probably not the best solution for an off road chain. I use whatever chain lube is cheap and apply it before ridiing. Before putting her to bed for the night I'll spray it up with some WD-40.
Old Apr 9, 2006 | 09:16 AM
Thanks for the advice,I will stay away from the graphite.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
