hot cams question
Old Apr 15, 2006 | 10:44 PM
Leroy400ex's Avatar
Default hot cams question
i have some questions about my hot cam that i just purchased for my 2005 400ex. has anyone put a stage 1 hot cam in one of these ATVs WITH OUT a big bore kit? if so did you notice a good amount of power increase. will i have to re-jet my ATV after this is installed? im having my honda dealer put this in my ATV so im sure they will tell me what im going to need. i just would like some sort of heads up before i bring it in. is there anything else that i need to know about hot cams??? please respond ASAP, Thanks.
Travis
Old Apr 16, 2006 | 12:35 PM
TractorPacker's Avatar
Do you have a balloon?
You might have to lean the carb out a little. The cam will pull more air through the carb, which will draw up more fuel. If it sputters and runs bad, try jetting it down one main at a time. If it runs good now, it should atleast start and run after the cam.
Old Apr 16, 2006 | 12:38 PM
fixitman69's Avatar
You will notice a little hp change with the cam, but if your motor is still stock, it won't be a dramatic difference. Your dealer will have to rejet your carb when they put the cam in. My suggestion would be to start out with a higher compression piston if you are looking for a very noticeable hp gain. The hotcam will go nicely with a 12:1 or a 13:1 piston.
bigred20653
Oct 2, 2015 10:05 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Brandon400
Sep 5, 2015 08:44 PM
