part ???
Old Apr 16, 2006 | 10:33 PM
87250xman's Avatar
Default part ???
The holes in the rim on my 250x where you bolt it to the axle there are little washers. I think the snug up the hole so its fits better on the axle. Anyway one was half broke so I went to my dealer to try to order one and the guy had no idea what I was talking about. Does anyone know where I can get one and what its called.
Old Apr 17, 2006 | 12:24 AM
TractorPacker's Avatar
Do you have a balloon?
Default part ???
Those steel inserts are pressed into the aluminum wheel. If you found one you wouldn't want to use it.
Old Apr 17, 2006 | 02:08 AM
fixitman69's Avatar
Default part ???
I would just buy 1 new wheel, they aren't that expensive. Don't try to modify wheels. When they come off at high speeds, it's not a pretty sight.
Old Apr 17, 2006 | 03:05 PM
ONEANDONLYDWT's Avatar
Default part ???
That happens when your wheels are not tight. I had the same thing happen to me. Check on some aftermarket wheels they may be cheaper.
Also make sure your lugs are still in good condition they may need to be replaced.
DWT
1986Vmax540
Jul 9, 2021 09:53 PM
DFWSRT8
Aug 20, 2015 09:24 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 28, 2015 01:58 PM
