350x Carb on a Mojave 250
Old Apr 20, 2006 | 11:37 PM
ERBEDS650's Avatar
Default 350x Carb on a Mojave 250
Just got a 400ex Carb for my sons 350x and was wondering if the 350x's would be a good replacement for the mojave carb.
Old Apr 21, 2006 | 05:47 PM
rolsmojave3's Avatar
what size is it, my guess is that it will not flow as much as the stocker, just get the 36mm from CWR when you have the money. Great add-on...you will have a smile gaurenteed
Old Apr 21, 2006 | 07:00 PM
ERBEDS650's Avatar
Ok listen up if I asked for a 36mm ok then I would put a 36mm on OK, bottom line the stock carb sucks those vacume diaphams are just junk, haqd on my DS, went to a TM, a 350 is 100cc bigger so the 350x should work out its close to a 32 mm which is close to the stock size on the mojave, and having teh butterfly slide it should have better throttle responce over stock, plus its free and free is always good!!
Old Apr 21, 2006 | 10:13 PM
holeshotz8436's Avatar
if the 400ex carb was a upgrade to the 350x carb you would loose power putting the 350x carb on ur mojo.....flow bench and tests done by people show that the 400ex carb flows and performs alot worse then the stock mojave carb and the size of the stock mojave carb is 34mm...........i would just go with a 36mm round slide like rols said
Old Apr 21, 2006 | 10:51 PM
Is the 350x carb smaller?....that might give you some bottom end power, but just kill top end
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
