350x Carb on a Mojave 250
Ok listen up if I asked for a 36mm ok then I would put a 36mm on OK, bottom line the stock carb sucks those vacume diaphams are just junk, haqd on my DS, went to a TM, a 350 is 100cc bigger so the 350x should work out its close to a 32 mm which is close to the stock size on the mojave, and having teh butterfly slide it should have better throttle responce over stock, plus its free and free is always good!!
if the 400ex carb was a upgrade to the 350x carb you would loose power putting the 350x carb on ur mojo.....flow bench and tests done by people show that the 400ex carb flows and performs alot worse then the stock mojave carb and the size of the stock mojave carb is 34mm...........i would just go with a 36mm round slide like rols said
Mojave250A
Jul 11, 2015 10:38 AM
