Wobbley tires
I have new 26" swamplites, and they all wobbel! IThe tire reads "550lbs max at 7psi" Do i run 7, or higher-lower? Someone told me to run 5psi, and now they are bad. At 8 they were pretty good, except for a slight wobbel in one reaer tire. Is this normal? they arent radials, just an agressive all terrain tbias tire. Any info would be great
7 PSI is max pressure for riding. Once the temperatures get up in the 70s the tires may straighten out a bit. Or you could put the bike inside and jack the thermostat up and boost the pressure to about 10 PSI and let it set a couple of days. Then drop the pressure back to 7 and go. Then again the tires could be warped and will never straighten out.
Sep 30, 2015 01:37 AM
