Starting troubles.
Old Apr 29, 2006 | 12:17 PM
jwmm04's Avatar
Default Starting troubles.
I went out to try and start my DS650 today, and I press the starter, and all it does is, turn the starter. It doesn't turn the motor over, sounds like it isn't grabbing or something. What's my problem? Anyone else have anything like this happen before?
Old Apr 29, 2006 | 12:53 PM
FatHolly's Avatar
Can you pop start it... that could narrow it down to the starter or related parts. If you can start it then pull the starter out and have a look... its really easy, two bolts and you can get a good look in there.
Old Apr 29, 2006 | 01:00 PM
jwmm04's Avatar
Yeah, I just had the starter out, It looked ok. I think the starter is working. It will turn over sometimes, but 90% of the time it won't. Frustrating!
Old Apr 29, 2006 | 01:27 PM
FatHolly's Avatar
If its only working some of the time I am guessing that you starter would be your issue. Connect it straight to a 12 volt source, and ground it, to see if its working all the time. That way, you could rule out any wiring problems.
Old Apr 29, 2006 | 02:13 PM
bombdsbaja's Avatar
Sounds like the starter motor is fine...but it sounds like the bendex is not engaging the gears....so it just spins the starter motor...but the engine isn't turning over....
Tom
Old Apr 29, 2006 | 05:15 PM
jwmm04's Avatar
Tom
Thats exactly what I was thinking, the starter always works, it just doesn't turn the engine over. What's wrong?
Old Apr 30, 2006 | 12:48 PM
jwmm04's Avatar
Anyone?
Old May 1, 2006 | 07:55 AM
jwmm04's Avatar
Come on, Someone has to be able to help me out!
Old May 1, 2006 | 10:32 AM
MRDS650's Avatar
Canadian and Proud of it !!!
I have had this problem a few times. My problem was in the switch. I have replaced the multi function switch (handle bar mounted switch with starter/headlight buttons) twice now.
I do believe there is a test that you can do in the manual as long as you have a multi meter.
If you don't have a manual drop me a pm and i will copy the pages you need and fax them too you.
Hope This helps
[img]i/expressions/face-icon-small-smile.gif[/img]
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
