piston deck height ?
Old Apr 30, 2006 | 01:55 PM
crazypainter's Avatar
Default piston deck height ?
Does the HPR 105.5 piston have a different deck height than the stocker? The pami does, so you can't put that in a sleeved cylinder. If the HPR piston will work it might be an option for a lighter piston than the JE or CP shelf pistons in a sleeved cylinder.
Old Apr 30, 2006 | 06:29 PM
ScoobyDFW's Avatar
don't know about HPR piston.
the JE shelf piston (~105.0mm bore) is a very light piston design. I posted some pics in the past. for $160 it's hard to beat but only comes in 11.5:1 CR. i'm working with JE on the piston ring package - not sure the rings they send with piston is ideal.
http://forums.atvconnection.com/mess...hreadid=481573
Old Apr 30, 2006 | 06:33 PM
I wanted a little more compression than 11.5, thats why Iwas wondering about the HPR. But for $160 I might give up a couple ponies and lighten my hubs instead. Thanks Dave[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 30, 2006 | 07:30 PM
yjacket2001's Avatar
That's a good point. Other than horizontal piston porting for reliable compression and precise CR, the weakest link is the rings.
And there is not much information on rings except lots of part numbers in JE manual. That alone may be reason enough to get the custom pistons.
May be mostly what piston designers do is calculate ring combination effects and complex interactions with the selected piston.
Sounds like a significant difference in performance/compression/reliability with the right rings alone. Two things I will require are customized pistons and exhausts. Other than 450r carb and sealed top end/head, that should be all I require for engine performance items.
Good Post Scooby. Thanks!!
exmotocrosser
Sep 13, 2019 06:12 AM
badgerboy1
Sep 26, 2017 06:11 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
