Help- How much to rebuild Rancher 350 motor???
Old May 5, 2006 | 09:49 PM
PointMan11's Avatar
Default Help- How much to rebuild Rancher 350 motor???
Looking for input on about how much it costs to do a basic rebuild of my 02' 350 Rancher 4x4 motor. Motor is running okay but she is puffing blue smoke when you get on it. I'm new to this so any help would be appreciated.
PM11
Old May 6, 2006 | 03:13 AM
LOANSHARK's Avatar
you could probably get by just replacing the rings... shouldn't be too expensive.
How many miles/ hours do you have on it?
Old May 6, 2006 | 09:56 PM
BigALFX4's Avatar
It sounds like it just needs a top end rebuild which if you do it your self it should only run you around 300 bucks
Old May 8, 2006 | 12:05 AM
quicksilver's Avatar
I agree. New Piston, rings, bore the cylinder, and replace the wrist pin and bearing if it has a separate wrist pin bearing. Also check the valves and replace the valve seals. That will probably fix your smoking issues.
Old May 8, 2006 | 07:53 PM
PointMan11's Avatar
Loanshark,
Not sure how many hours are on it. I bought from the 2nd owner but I'd say at least 1,000 miles, proabably more just by the overall wear-n-tear on the machine. I have not put any time on the machine yet, since I gave to a mechanic friend to do some basic repairs to brake cables, CV boot, etc.
He just informed me that the top end looks like in needs to be re-done, too. I might just do some light duty riding for a month or so then do the top.
Thanks for the reply.
PM11
Old May 8, 2006 | 07:55 PM
PointMan11's Avatar
Quicksilver,
Thanks for the info. I'll look into that after I tuck a few more bucks aside.
PM11
PointMan11's Avatar
Thanks Big Al
Kaleb_00
Jun 1, 2016 09:15 AM
ronnierhino06
Nov 9, 2015 12:56 PM
ghost civic
Jul 27, 2015 03:15 AM
Scottma518
Jul 16, 2015 09:19 PM
ghost civic
Jul 15, 2015 10:48 PM
