crooked handle bars on a raptor
Old May 8, 2006 | 08:07 PM
bodydropcris's Avatar
Default crooked handle bars on a raptor
had alittle spill on my 660 today, and later i noticed the handle bars were turned alittle to the right when the quad was tracking straight. did i bend something or is there a way to adjust this?
Old May 9, 2006 | 02:52 PM
should i pull the steering shaft and move it over a spline?
Old May 9, 2006 | 03:12 PM
01Raptor's Avatar
The spline did not move if the nut at the bottom was tight. Moving it over one spline might straighten you bars for you but it did not correct the twisted part. More than likley you twisted your stem.
Old May 9, 2006 | 04:46 PM
yeah the nut is tight, it landed on the right bar because i noticed the throttle lever and brake lever and fluid container were scratched up. i guess im going to pull the steering shaft out and look at it, then see if moving it over a spline doesnt straighten it up. btw the bars are not bent, you can look at the mount for the handle bars and see that it is turned too. my manual doesnt say anything is adjustable, so i guess somethin is bent.
Old May 9, 2006 | 08:42 PM
well that wont work, its keyed so it only goes in one way. guess i'll take it to a shop and see if they can straighten it.
bmxatv10
Oct 14, 2022 06:23 PM
Valder
Nov 28, 2020 07:38 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
