250ex reloacating the key
Old May 13, 2006 | 03:06 PM
XxBamBam2xX's Avatar
Default 250ex reloacating the key
i might sound stupid but i ahve a 250ex 2001 i was wondering if it is easy to relocate the key so i dont have the big black plastic thing there so please help me out im not gonna do it if it is too hard
Old May 13, 2006 | 05:52 PM
CoyoteRiverRaptor's Avatar
Hey Bam, we bought the Trial Tech handle bar kit for the 450R. We got it without the logo. The chrome mount looks sharpe and includes a small for the key and one indicator light. We drilled another hole in the plastic key mount so that the two lights symetrical above the key. It looks great.
You have to grind that little wire cable guide off, loosen your top mount for the brake line, and mount your choke in the front plastic.
For the choke mount drilled a hole then used a carpet knife to split the plastic to be able slide the choke mount thru the plastic. The plastic is real thick in the front part of the steering stem opening so the choke is very sturdy.
By doing these these mods I was able to use the Trial Tech Hi-bend bars.
Another cool aspect to this that you can the add the Trial Tech light mount ($15.00) to the trick handlebar mount then you can add a pair of the Trial Tech HID lights and have a great little night rider.
Or just drill the holes in the front plastic notch the key mount with a file, follow the key cable back and unplug it and run back through the hole in the plastic and drill the indicator holes for the light using the ugly black piece as a size guide.
CRR
Old May 13, 2006 | 06:02 PM
thanks a bunch for replying im probably just gonna do they last thing you told me is it worth doing right now or waiting until i get some black maier plastics this christmas
Old May 13, 2006 | 06:05 PM
the main reason im doing this is because im buying some new renthal handle bars and it looks way to squshed right there but if it is going to be too much trouble i might just wait
Old May 13, 2006 | 06:06 PM
also where exactly should i relocate it too i was just thinking and i really dont know where to put it
hondarider1234
Jul 21, 2015 11:53 PM
cSchwartz
Jul 9, 2015 02:40 PM
Rider252
Jul 6, 2015 03:37 PM
Jake55
Jun 29, 2015 06:43 AM
DSAPP
Feb 1, 2001 09:49 AM
