Radiator fluid?
I just added Water Wetter. I haven't had the chance to really put it to the test but I did notice that at idle the fan runs for a shorter duration than before. I am hoping to add a temp gauge soon. On the couple of short trips I did take, when I was cruising at 25-30 mph, the fan never did come on. I thought about Engine Ice but I wanted to maintain my anti-freeze ability. Besides that, it was alot cheaper and was considerably easier to add to the system.
I always drain my anti-freeze for the summer for obvious reasons and run a coolant like
"Liquid performance Racing Coolant" and also use an oil coolant which decreases motor temperatures.
Generally a coolant specific product will keep your motor much cooler than anti-freeze.
I haven't had any problems draining the anti-freeze it's pretty easy.
The oil coolant is called " High Lifter Motor Cool" and you can get it at Dennis Kirk if not at a local shop.
My quad does seem to run cool but I use the products on advice from a tech I know who races and works
at a local shop. I figure it can't hurt.
jrooker6
Apr 23, 2016 07:36 PM
Logan Collins
Sep 5, 2015 08:03 PM
