Rhino backfireing, bogging, stalling, no power
Old May 14, 2006 | 12:04 AM
muddbogger's Avatar
Default Rhino backfireing, bogging, stalling, no power
My rhino is about 6 months old and i never got it serviced yet. now it backfires at high rpms then cuts out, i can deffenetly feel a power loss, i cleaned the carbureator and the air filter.....problem not solved.....any thoughts? could it may be the oil or sparkplug? thank you....jerry
Old May 14, 2006 | 01:52 AM
squeege's Avatar
What size rhino? Where do you ride(conditions). How many miles are on your rhino?
Old May 14, 2006 | 10:13 PM
muddbogger's Avatar
660, i beat the **** out of it....train tracks, woods, rocks, mud, trails, feilds, hills, no clue about miles tho
Old May 14, 2006 | 10:25 PM
MuddyGrizzly's Avatar
were the valves ever adjusted ? If not that may be it!
Old May 15, 2006 | 09:16 AM
RAPTORJUNKIE's Avatar
Thats my first guess.
Old May 20, 2006 | 09:46 PM
BamBamRhino's Avatar
Two things here.
First check your fuel filter I would bet it is the culpret. I had mine clogged and I cleaned it out and then eventually replaced it. Problem fixed. [img]i/expressions/face-icon-small-happy.gif[/img]
Next make sure you had your initial tune up. The intake valves tighten up and the exhaust normally don't. So once the adjust them you should be in good shape.
My guess is the fuel filter behind the passenger seat.
Bam Bam
One Bad Rhino
Old May 20, 2006 | 10:49 PM
OryGun's Avatar
Was having the very same problem with my 600 Grizz. It would start and run at low speeds but as soon as I went into 240 Gordy mode it would miss and pop and weeze... After setting all winter I tryed to start it so I could load up and go spend $200 to have the carb rebuilt. Wouldn't start.
I pulled the plug and took a good look a the spark... Guess what? There was very little and it was sparking around the post. A minor adjustment and I am now ready to push over schools again..
Good luck
scram5050
Aug 30, 2024 01:39 PM
mtdewmn
Jan 19, 2017 12:13 PM
momma's bike
Aug 6, 2015 09:49 AM
fire1998
Aug 6, 2015 02:46 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
