Foaming fuel in carb bowl?
Old May 14, 2006 | 10:07 AM
Kahnman's Avatar
Default Foaming fuel in carb bowl?
I put new drag race engine mounts on the race chassis and the engine is transferring more vibration to the carb causing the fuel to foam and bubble up in the carb. This is causing a bad operation and the rpm's don't always want to come back down. Anybody else have this problem and how to fix it?
Old May 14, 2006 | 03:04 PM
dontgetbehindme's Avatar
Are you sure that you don't have a 4 yr old child like mine that might put soap in the gas tank. LOL
IS the mounts the only thing that you have done to cause this?
Old May 14, 2006 | 03:52 PM
Kahnman's Avatar
YEP. I hold the carb and the problem goes away, for the most part. [img]i/expressions/face-icon-small-blush.gif[/img]
Old May 14, 2006 | 06:36 PM
I never heard of a motor doing that. Does it have a counter balance shaft and if it does could it be out of sync?
Old May 14, 2006 | 07:25 PM
Kahnman's Avatar
Yes it does and ye4s it is all in sync. The other mounts were soft and the motor just "floated" in the other mounts. These are very hard and transmits more vibration thru everything atached to it. [img]i/expressions/face-icon-small-frown.gif[/img]
Old May 14, 2006 | 07:32 PM
duneaholic's Avatar
I zip tie my carb to keep it from moving around...it seemed to help quite a bit.
Old May 15, 2006 | 01:27 AM
Try this then, take some wheel weights and tie to it and see if it helps. If you could fix a bracket from the air box to the carb to reduce the vib. Just my 2 cents in a $3.00 a gallon of gas days. LOL
skinnyr6
Aug 25, 2023 02:18 AM
micheleLeigh
Jul 12, 2015 02:50 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
