yamaha brakes
Old May 15, 2006 | 12:50 PM
hunteraz's Avatar
Default yamaha brakes
I have a 00 bear tracker. I was trying to check the brakes and I can not get off the drums. I took the tires off, removed the castle nut and cotter key, but the drum wont come off. I tried every wheel and got the same result. Am I missing a bolt or is there a trick to getting them off?
Old May 15, 2006 | 06:18 PM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
I'd try hittin it off w/ a rubber mallot, works on drum brakes on cars.
Old May 15, 2006 | 10:09 PM
Roush412's Avatar
Yea I would use the same method for cars also. Make sure you leave one lug nut on then hit it with the mallot so the drum doesnt go flying off when it breaks loose.
Old May 16, 2006 | 12:49 PM
hunteraz's Avatar
ive hit it pretty hard but ill have to try it again.. thanks for the info
Old May 16, 2006 | 02:24 PM
Roush412's Avatar
Try some pentrating oil on the studs that could loosten it up.
Old May 16, 2006 | 04:22 PM
warriorryder's Avatar
loosen the brake cable...i did that on my front brakes and they came right off
Old May 16, 2006 | 06:20 PM
hunteraz's Avatar
losen the brake cable at the lever?
Old May 16, 2006 | 06:22 PM
no the cable at the wheel...the one at the handlebars doesn't really do much
Old May 16, 2006 | 06:42 PM
hunteraz's Avatar
cool. thanks
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Oct 16, 2019 12:11 PM
greg74
Sep 10, 2019 03:03 PM
Stirling
Aug 9, 2015 01:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
