sp 700 big bore or stroker kit?
Old May 16, 2006 | 06:51 PM
TJ700's Avatar
Default sp 700 big bore or stroker kit?
cant seem to find anything solid as to wheather there is anything available or not.
Old May 16, 2006 | 07:17 PM
Kerbbirds's Avatar
From what I understand you can use the top end and pistons out of a 800, should bolt right up that would make it a 760.
Old May 16, 2006 | 10:45 PM
spyder6's Avatar
any bore or stroke work will have to be custom, there arnt any companys that make a kit
Old May 17, 2006 | 10:45 AM
Speedwerx's Avatar
The 700 and 800's actually have the same size bore the 800 has a longer storke though to get it to 760. There isn't any room in the cyl design to go any larger with the bore. If more hp is what you are after you shoudl consider on of our camshafts and head porting. We are also starting to work on a new head set-up with larger valves too.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
