700r
Old May 19, 2006 | 08:07 PM
700raptor's Avatar
Default 700r
hey now i know this is the bomb side of the world... but i ddint think id get to much help over in the yami forum and since you folks seems to know your sh*t and have your heads screwed on right i figured id give it a shot....heres the thing... the only thing i have done to my 700 is slip on and intake... if i were to send the motor to trinity get the port job and the bore and 12.5 piston, programmer and the head pipe.... what kinda numbers would i be puttin down like hp wise... a buddy of mine told me that i would be close to 80 hp now befor yall go jumpin my sh*t about this accusation... i dont believe him thats why im here askin opinions.... thanks in advance for the feedback.....
Old May 19, 2006 | 09:20 PM
rfwlll's Avatar
Default 700r
Good question. But I don't think you'll get an answere, because there is'nt any profiles of what you want done. As of now all we know is that you want 12.5-1 comp, the other things need specs. But I would say that if all that work is top notch and specs are high than I would say it is deff. possible.
Old May 19, 2006 | 09:33 PM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
Default 700r
depends on the size of the bore and the quality of the port work, but i'd say 80 hp is pushing it if u are talknig about the trinity 734 kit. i'd think more around 65ish
Old May 19, 2006 | 09:48 PM
700raptor's Avatar
Default 700r
still 65 is pretty descent for what i do so i believe i would be satisfied.... besides i think with me 80 hp would be overkill... well then again i guess you cant really ever have enuff on these .... but anyways thanks for the help
Old May 19, 2006 | 10:07 PM
2BIG2BFAST's Avatar
Default 700r
get those 65 hpppp and then add another 20 or so with a shot of the laughing gas, i bet that thing would fly. you can never have too much horsepower
Old May 19, 2006 | 11:36 PM
FatHolly's Avatar
Default 700r
I would tend to agree with what has been said already. 80hp seems a little high for just pipe, piston, and porting. 65hp seems resonable. Do they add cams as well? I would think the addition of cams would easily put you at 65 with the correct porting. What is the base line for the 700r?
Old May 20, 2006 | 12:43 AM
Majorecho's Avatar
Default 700r
80 on Trinitys dyno could be 55-60hp on another dyno- since dyno's are not universally calibrated equally and setup is varied from operator to operator and machine to machine the results can be misleading. Once again a dyno is a great tunning tool. You will definately see power gains with the changes you are thinking about, my question is, what software is available to upgrade the EFI and what injectors are you planning on running? I believe stock 700 injectors max out around 60-65hp on gas and you don't want them running 100% duty cycle.
Old May 20, 2006 | 01:50 AM
DSNUT's Avatar
Default 700r
Trinity claims 27 hp gain from their fuel management system which i believe includes injectors, their pipe and intake, race porting, cam and the big bore kit...........all at 12.5:1 compression. A piped 700 seems to be running from 47 to 50 on the high end on most dyno tests. Subtract about 6 hp because you can't count the pipe and intake twice and you have somewhere between 68 and 71 hp. Based on those mods I think those would be reasonable numbers..........except that it is Trinity that is giving them out. They are always very optimistic about their own products. I would be disappointed if I got 55 hp and ecstatic if i got 65 out of this kit...........assuming a bike that dynos in the 41 - 44 range stock.
I agree with Majorecho about the subjective nature of dynos. Great tuning tools but that is about it[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 20, 2006 | 02:34 AM
700raptor's Avatar
Default 700r
see thats the thing i never really got into highly modifing my warrior... what i used to have... i put full exhaust intake and gotit rejeted thats the thing so im not really up to speed on cams and stuff but on this bke i want it to set out from the rest of the crowd... obviously thats not an option with the way you gys are setup but here the folks around here tend to slightly modify but i am goin to the dunes for the first time in august im goin down to the outer banks in north carolina to see how i like it... but back on track... what should i do and what should i not do.. i mean if i put cams and get it punched out and all the goodys how badly will it affect the reliablility of this motor... plus most of the time i am in the trails but when i want to go i want to know that no one can touch me.... bye the way thanks to all of you for your help i feel like a total greenhorn here so thanks for being patient.....
Old May 20, 2006 | 02:37 AM
700raptor's Avatar
Default 700r
i almost forgot... does anyone know of anyone puttin a shot on a 700 yet and if so how it reacted
