97 trail boss parts needed
Old May 19, 2006 | 11:42 PM
new24's Avatar
Default 97 trail boss parts needed
hello, i just picked up a 97 trail boss 250 4 stroke but it needs a few things and was wondering the best place to get them, i need a cdi, the one on it got crunched, it is also missing the key, the guy i bought it from said he hid it and now can not remember where?? also the front axel on the left side is bent a little, he gave me a clymer book with it and it looks like it is called a steering knuckle, if i can get it running i would like to replace some of the plastics also, thank you for your time and help .....eric
Old May 21, 2006 | 09:45 AM
new24's Avatar
i am sorry, this is a 2 stroke, i need a cdi, the one on it looks like it got crunched but i am not sure if it works yet or not, it needs a front left lower strut/axle i think in the book they call it steering knuckle, it is the part the axle goes into and holds the brake and the spring and shock sit on top, also need a pet **** lever to turn the fuel on and off, and a battery, also is there a way to make sure this is a 97, the ser # is stamped under the seat 4XAAA25C6VC004163 and the numbers on the engine are mod#1341151 ser# 96-06893
Old May 21, 2006 | 10:25 AM
Blaster200FMF's Avatar
On the polaris trailboss , its easy to tell things by the vin,
the first 3 numbers on the vin are world MFD ID numbers
the 4th number is the body style
the 5th is powertrain
numbers 6 and 7 are engine, which for yours is a 25 which is 250cc
number 8 is emissions
number 9 is nothing
the tenth number is the model year , yours is a Y I beleive Y was a 95 or 97 not sure but I can look it up later if you want.
the 11th number is the plant number where your quad was made
numbers 12 through 17 are serial numbers
hope this helps you ,
FYI , ebay has every part you will need for your trailboss , cheap to , give it a try.
Old May 24, 2006 | 10:44 AM
new24's Avatar
i think this is a 95 from the pictures i have seen of other 95s unless they did not change them for two years, i did get a key, now i need to test the cdi and see if i get it to crank or if i have spark, thanks for your help ...eric
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
