K&N Air Filter Oil
Old May 22, 2006 | 09:52 PM
UKHONDARANCHER's Avatar
Default K&N Air Filter Oil
Will K&N Air Filter Oil work on a stock foam filter for my Honda Rancher. This Brand is all I can find. Thanks.
Old May 22, 2006 | 09:59 PM
TractorPacker's Avatar
Do you have a balloon?
No, use motor oil, if you cant find foam ai filter oil.
Old May 22, 2006 | 10:48 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I wouldn't. K&N oil is very light, and will "drain down". So will motor oil.
Use one of the thick, tacky oils like Maxima FFT.
Old May 22, 2006 | 10:52 PM
He can't find it, though. Motor oil will stick long after k&n oil, therefore it would be better.
Old May 23, 2006 | 12:30 PM
quicksilver's Avatar
i would not use motor oil either, it might make the glue for the filter come apart. You'll have to look around for foam filter oil.
I use the UNI filter oil on my stock filter it sticks to the filter really well, better than the AMSOIL high-tack oil. I also found out that UNI makes the stock foam Honda filter, just to give everybody a heads up.
Old May 23, 2006 | 02:25 PM
zex129's Avatar
Ive been using BellRay foam filter oil on my stock vinson filter and KQ with uni filter. Good stuff!
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
