what's wrong with the raptor 660r?
Old May 24, 2006 | 04:47 PM
450rking's Avatar
Default what's wrong with the raptor 660r?
i am looking in to geting a used raptor 660r and i want to know if ther is anything wrong with them i have herd that thay are tipy if so how tipy are thay and are thay good jumpers and good at wheelys thanks for any info
Old May 24, 2006 | 04:55 PM
RadRaptor's Avatar
They had a bad rep in 01 with bad tranny's. I got an 01 and haven't had a problem. They are a lil tippy but I have an extended axle on mine so never had a problem. They are wheelie monsters dude. I just finished turning mine into a 673 with Wiseco high comp. piston and Hot Cam stage 1 and it is sick man.
I just purchased a 06 700R Raptor and am selling my 01 with all kinds of mods. Let me know if your interested.
Old May 24, 2006 | 05:42 PM
fasterthanyou22's Avatar
I have a raptor 660r in great condition, bout to get a tune up here, change oil, oil filter, and adjust valves...very very good bike man. Its a 2001, and i have not had a single prob with the tranny.
Old May 24, 2006 | 06:55 PM
Raptor149's Avatar
Here are some things I discovered over the four and a half years I have owned my Raptor:
1.Inspect the water pump housing and the areas around it. If you see any coolant leaking, or if the weep hole on the bottom of the housing is wet with fresh coolant, the pump may be going bad. A replacement pump runs about $50 at your Yamaha dealer, and is easy to replace.
2.Ask the owner to adjust the rear chain for you. The adjustments are one of the worst ever conceived. It is easy for the adjuster bolts to seize and break off in the carrier. This is a giant pain in the @$$, can be costly and is not easy to fix.
3.Listen carefully to the starter as it turns over. Any knocking, grinding or rubbing noises can indicate the starter bearing is going bad.
I think those are three of the more common problems Raptor owners have, besides jetting. But if you take for a test ride, you'll be able to tell if the jetting is off. I have had very few problems with my Raptor, it has been a great machine.
While many people with 01's have not had tranny problems, you'll find it was a serious issue for that model year. Another thing to consider. Good luck.
Old May 24, 2006 | 07:04 PM
YamahaRider8998's Avatar
ive also been looking into a raptor and ive heard people say that the starter clutch on the 01s are known to go but it is much less common.
steve
Old May 24, 2006 | 10:35 PM
Yoshimura660's Avatar
IMO the raptor is just an all around great quad with great power and can wheelie like wow.
Old May 25, 2006 | 12:02 AM
AustinONeal's Avatar
for the chain issue get an aftermatker swinger i can adjust mine in about 3 minutes
Old May 25, 2006 | 08:35 PM
450rking's Avatar
thanks guys i think just to be safe if i decide to get one i will get one newer than 01 but as soon as i sell my 400ex i will probubly buy a raptor
Old May 30, 2006 | 07:57 AM
03RaptorFan's Avatar
what are you asking for the 400??? cuz im thinkin about sellin my rappy.
Old May 30, 2006 | 08:45 AM
450rking's Avatar
$3500 or best.
bvolks
Sep 13, 2015 12:57 PM
Alex Rodak
Sep 11, 2015 11:42 PM
1ArmBandit
Sep 8, 2015 08:59 PM
black_thunder
Sep 7, 2015 01:24 AM
black_thunder
Sep 6, 2015 04:41 PM
