Trying TO Find Rocker Arms And Racing Valves And Cam For Trx250x
i am trying to find new cam chain, cam gear, racing cam, racing valves and race rockers and i cant find any anyone know good sites or good places to find racing parts for them
IN NEED OF RACING PARTS
Thanks Alot
trx250x 1992= supertrapp shorty exhuast, K&N, Jets, high comp pro-x piston,
Thanks Alot
You should be able to use parts for a 300ex, the motors are identical, the only difference is the electric start, and the 300 has a longer stroke rod, the heads, cams, etc, are pretty much the same, the 250x had a slightly better cam in it from the factory, but racing cams for the 300ex should work just fine, along with all other motor parts.
Some sites to look at:
http://fourstroketech.net/
http://www.webcamshafts.com/
http://www.powroll.com/
And for everones information, the 250x and 300ex are NOT the same!! The 300 has alot wider gears in the tranny. You cannot swap tranny parts!! They are also a very slightly different ratio. The cases are also different. They are machined to clear the gears on a 300. The cranks are different. The heades are different. They use different volumes, although they can be swaped. Most of everthing else is the same.
