86 250 fourtrax utility went into a pond
Old May 30, 2006 | 06:25 PM
gswarrior2002's Avatar
Default 86 250 fourtrax utility went into a pond
A friend drove my 250 fourtrax into a pond, I can tell you first hand the quad floats.
everything bit of the quad was under water all you can see was the rear rack floating for at leat 10 min. the quad was shut off right away. what kind if damage should I expect. I drained the oil from the crank case,yes water in the crank case. took apart the carband drained the bowl ,drained the gas tank. Now im just letting it sit to dry out a couple of days. Do you think it will run again?.
Any body else experience this..........
Old May 30, 2006 | 06:59 PM
fixitman69's Avatar
I wouldnt let it sit long, internal parts will start to rust. Drain all your fluids, refill them and run it for about 10 minutes, yhen change all the fluids again. you should be good to go after that.
Old May 30, 2006 | 10:34 PM
TheQuadSport230's Avatar
Just repeat that Until the oil looks good then rechange it again...
I would clean most of the water out first since you don't want to have too much water in the cylinder since it does not compress (read: Not good for your rod)
Old May 31, 2006 | 08:33 PM
thanks for the help guys
she is back togather and running....... need to change the oil 1 more time thou.
Old May 31, 2006 | 10:45 PM
fixitman69's Avatar
Glad we could help.
Old May 31, 2006 | 10:49 PM
Glad we could help.
[img]i/expressions/face-icon-small-smile.gif[/img]
Johnny Mac
60
Dec 14, 2019 06:13 PM
wendal
Oct 31, 2017 03:31 AM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
wendal
Sep 15, 2015 01:50 PM
