oil in the airbox on predator. Whats going on?
Old Jun 1, 2006 | 11:56 AM
BlackRaptor's Avatar
Default oil in the airbox on predator. Whats going on?
Hey guys i just opened my ait box on my pred and it's got a lot of oil in hte bottom of it. i pulled those little dirt catchers on the bottom of the air box and both where full of oil.
What would cause this. i hope it's nothing bad.
Old Jun 1, 2006 | 12:23 PM
ppope's Avatar
Have you had it on a very step hill, or even turned it over?
Old Jun 1, 2006 | 12:43 PM
I've hill climbed some really steep hills wide open in lower gears.
Old Jun 1, 2006 | 02:11 PM
ppope's Avatar
They can do this when turned over, or put on an extremely uneven surface. Clean it out and ride it normal for a while, then check it again......
Old Jun 1, 2006 | 02:57 PM
heatseeker8's Avatar
Well If you havent rolled it over and havent climbed a good share of steep hills, Its because of the Crank case breather.
What happeing is oil is getting to the top the crank case (AKA oil blow by) and it gets vacummed to the crank case breathe tube into the "dirt catchers".
Have you done a compression check yet?
Old Jun 1, 2006 | 03:12 PM
Compression is good
heck the bikes only got 6 rides on it now haha
i picked it up as a left over model.
Old Jun 1, 2006 | 04:42 PM
ppope's Avatar
It might have been left over for a reason.
Old Jun 1, 2006 | 05:20 PM
Webopper's Avatar
Check your oil level. It might be too full. Not uncomon for some oil to get in there because that is where the crankcase breather is located, but if it's excessive, it probably because the oil was overfilled, or the bike has been turned over.
Do like ppope said...check the oil level and make sure it's not over the recommended levels, then clean everything out and run it for a while and check it again. I'll bet you find it's fine.
Old Jun 1, 2006 | 06:02 PM
ScramblerXLE's Avatar
*agrees*
Had a buddy pick up an '03 used from a suzuki dealer. since the dealer didn't look into how your supposed to check the oil on the pred (run it for a minute, shut it off then check, otherwise it will appear low) they just filled the oil tank to the top. When my friend started riding it, the airbox was filled with oil up to his uni air filter. Good thing it was a UNI, since those are washable, no damage done... anyway, clean things up, and hopefully it's done w/ the overflow... otherwise, maybe change the oil and do it the right way. good luck! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 1, 2006 | 07:13 PM
DuneRider650's Avatar
I ride a little here and there......
If it does keep happening...its from the crankcase breather. I had the same problem on my ds, the crankcase breather was located in the snorkle tubes and then oil gatherd in my airbox eventually and made a fairly big mess. What i did to fix it was move the crankcase breather tube to a different spot and put a little K&N filter on the end of it. Another thing...the reason i was having all the oil comming out of the crankase breather is because my piston rings were screwed because of a bomb factory mess up..i had good compression. got new piston installed, new jug, and a fixed up head and no more oil ever comes outta the crank case breather. That prob isnt your problem like the guys said it might have just been overfilled or tipped over.
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
Dammar
Aug 26, 2015 07:12 PM
ghost civic
Jul 20, 2015 12:36 PM
1966F100
Jul 12, 2015 03:08 AM
