250R Big Bore
I have never had a sleeved 295 big bore, but from the looks of the setup it seems that to insert that large sleeve they actually have to bore farther into the water jacket of the cylinder(this makes sense). Anyway, everyone I have talked to says that once they get the sleeve in they overheat very easily. With less water jacket, less heat can be removed do you see where I am going with this? You would be better off getting the aftermarket 310 kit. With 2 times the cooling capacity of a stock cylinder, and probably 4 times as much as a big bore sleeved cylinder it would be a much more reliable engine.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
