Why Toe Out?
Old Jun 5, 2006 | 02:02 PM
oldstillgoing's Avatar
Default Why Toe Out?
On the SP 700 and 800 the spec's call for 1/8" to 1/4" toe out. Most things want toe in. Anyone understand the reason behind the toe out spec? Seems both of mine were out of spec. Seemed to cause hard steering. It is interesting to note when one backs up the steering seems to get easier. Wonder what would happen with toe in? Has anyone tried toe in, what was the result?
Old Jun 5, 2006 | 09:17 PM
powerslider's Avatar
While I haven't checked it the toe measurement may change through the suspension travel therefore they give you a spec that keeps it as close to optimum as possible. It may go to a toe-in situation on compressed suspension. Caster angle affects steering effort, positive caster moving forward will be negative caster in reverse hence the difference in steering feel.
Old Jun 5, 2006 | 10:48 PM
Doctorturbo's Avatar
GOT BOOST!
If you tow out the front end it will be more stable in the corners. The more towed in you have a vehicles front end, the more "trike effect" you will have. If you ever rode a 3 wheeler you know what this means.
Also, slight tow out on a 4X will give you slightly better bite on the front axel.
All of these effects are very small, but they are there.
Old Jun 5, 2006 | 11:17 PM
How does toe out effect steering force at the handlebars, compared to toe in?
Old Jun 5, 2006 | 11:22 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
I preffer to be toed in. as it deflects more often than hooks trail side objects.. adverse effects seem to make steering very stiff. toe out logically would make for lighter steering. and on those beasts lighter steer can be a good thing[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 5, 2006 | 11:26 PM
Monkey Rider
Afro-Engineer
Alignment theory
Old Jun 5, 2006 | 11:36 PM
VERY interesting read on toe in vs. toe out. Guess the bottom line is experiment. Trying for easy steering force at the handle bars. OneFlyCowboy, do you set yours with toe in?
Old Jun 6, 2006 | 01:10 AM
GOT BOOST!
As stated above, a slight tow in will give you slightly easier steering. A slight tow out will give you slightly better handling in the turns. Castor will really make things easy or hard, but I know of no stock quad that you can set that on.
Old Jun 6, 2006 | 01:33 AM
Monkey Rider
Afro-Engineer
I am always toed in. depending on where im gonna ride and the tires I have on. I adjust the severity. I don't care for toe out as it tends to be darty.
Old Jun 6, 2006 | 01:58 AM
Your answers and information is just what I hoped to find. Do you toe in the 1/8" to 1/4"? I want to give this a try and your experience is most useful. No need to reinvent the wheel short of thing. Thanks a bunch.
