Small 800 issues
Old Jun 7, 2006 | 03:14 AM
EasyQuader's Avatar
Default Small 800 issues
I think I have read here that the dealer will replace the front springs on a 1 up non xt with the stiffer xt springs under warranty if the owner says the front springs are too soft. True? Also, when starting from a stop the CVT seems to grab and be a little jerkey. Not slipping but not a smooth, easy start. Sometimes difficult to move a few inches when loading. Dealer says that's the way the CVT works. True? The stock air filter is as good as anything else. True? My fan comes on even when riding in cool weather and that is normal. True?
Old Jun 7, 2006 | 11:14 AM
Pastor's Avatar
Never heard of any of these issues...since the dealer is backing it up, he claims responsability (IMO). With that being said, enjoy the bike and overlook some of these things if you can...you always have the most astounding warranty in ATV history if you need it. I am having to get used to the "funny" engine noise of mine...just not used to it. But....the thing makes up for it BIG TIME in other ways.
Old Jun 7, 2006 | 08:06 PM
EasyQuader's Avatar
These issues were answered by the service writer who will foreget everything if the stuff hits the fan. Just thought I would ask the people that know things for a fact here, thanks.
Old Jun 7, 2006 | 10:02 PM
v2rider's Avatar
What type of warranty do you get??
Old Jun 7, 2006 | 10:58 PM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
im almost positive most of the bikes came with a 3 yr warranty, or a 1 yr with optional 3yr, something like that
Old Jun 7, 2006 | 11:00 PM
v2rider's Avatar
Oh. Bom and Arctic Cat must be the only ones with a 3yr warranty.
Old Jun 7, 2006 | 11:14 PM
chirochris's Avatar
- my fan runs alot also..even when cool
- they should replace front shocks if requested from a ride complaint
-jerking some have when new from the belt i think..not sure why but goes away..not 100% on this one just what i was told
Old Jun 8, 2006 | 03:13 AM
EasyQuader's Avatar
Twin Air now makes a replacement air filter for the 800, foam/oil type. I know it will filter very good but how does it flow? As far as the fan, I might add some water wetter but don't expect much change. If I had real heat problems I would look into an oil cooler somehow. I will make some phone calls tomorrow on the front springs.
Old Jun 26, 2006 | 03:17 AM
brewster2003's Avatar
I had this very same issue of the 800 being jerky at a little over idle speeds. At only 30 miles I took it back to the dealer and they said something stupid like "it'll probably work itself out in time, and ya really don't want me to tear into that thang do ya?" but having spent nearly $9K on a quad I was not going to accept that so I told them they better get to the bottom of it. Two weeks later they had it fixed. It was the clutch and they did replace it and the belt since the belt was scored. There was a spring broke in the clutch. They shipped in a new one and the spring somehow got broke in it as well, so they had to order yet a second clutch. They installed it under warranty and it is all running smooth as silk now, however I am crossing my fingers on these clutches as it appears something was either defective on a run of them or there is a brittle spring in them.
BTW I made them give me that 3 year warranty in writing.
Old Jun 26, 2006 | 10:55 PM
EasyQuader's Avatar
If the temp ever gets tollerable I will take it out again just to be sure it's not me .
